Switching Mobile Provider
Edwin10
 Requested the transfer from Koodo to Public Mobile .Got confirmation email from Public Movile but failed the the confirmation text of Koodo passed the 90 minute period . Now my Public Mobile SIM is still not working
@Edwin10
If you missed the 90 minute confirmation text. Your Koodo SIM should still work until porting is completed.
@Edwin10
There is a number to call to talk to live support,  they can re-trigger the process for you.  I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) .  Check the envelope icon on top right.  Call them and get it fixed
Add: but you said the PM sim is still not working? can you make outgoing calls? If not, then don't call the porting team, instead. open ticket with support
HI @Edwin10
there is a porting team to call.  Will message you now, check Community inbox.  But they close at 10pm EST. not sure if you can make it, or maybe tomorrow
