Switched to the 10GB at 3G plan but plans page not reflecting it
jace829
My payments history shows I switched to the 10GB plan 3 days ago, but my plans page shows my current plan as the 1GB plan. My usage is also showing I have only 1GB to use...what's happening?
7 REPLIES 7
@jace829   it is a bit unusual then.  Usually using a different browser or Incognito mode would have the latest update
And no, plan change does not need 48 hours to reflect on your My Account, it will show the new plan immediately as long as PM charged you
Please open ticket with PM Support to get them confirm if a plan change was made :
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
**Monitor your Community inbox (envelope icon on the top right) after the ticket is opened.  CS Agent will reply you there
jace829
I'm now seeing the new 10GB plan.
@jace829 wrote:
Thank you both! I tried a different browser and it looks like the information is up-to-date on there.
@jace829  So, are you still seeing the $25 plan with 1GB? or the new plan with 10 GB?
jace829
Meow
Use different browser; clear cache, use incognito/private browser mode
MrSpock
@jace829 hi clear your cache  or try another browser in private or incognito mode reboot your device and sign in again see if it updates
@jace829   I guess you clicked "Change plan now"?
It could be a browser cache issue
Please try to access My Account again using Incognito mode or try with a completely different browser (Firefox/Chrome/Edge)
