Switched to 5G
Colin11
I recently upgraded to 5G and 50Gb data effective March 10.   I’m seeing the 50Gb data but still showing 3G speed. Why am I not getting 5G?
@Colin11
Manually switch to 4G/LTE because the iPhone 11 is not 5G compatible.
https://m.gsmarena.com/apple_iphone_11-9848.php
Go to Settings>Cellular>Cellular Data Options>Voice & Data>click on LTE.
DennyCrane
The iPhone 11 is not a 5G capable device, but you can still get near 5G speeds with a 4G phone. If you're only getting 3G speed, it may be because you have your phone set to 3G. Check your device settings.
Colin11
Recently upgraded to 5G effective March 10. Although I’m seeing the extra data component, I’m still seeing 3G on my phone. In checking through Public Mobile customer support and asking the question, the answer is to check if my phone has 5G capability and that 5G is available in my area. I have an iPhone 11 and live in Sydney NS. How would I know if my phone is 5G compatible and if the service is available in my area? I assumed the 5G service is available in my area.
@Colin11
what phone do you have?
and check your Network mode, make sure it is not at 3G, choose 4G or 5G or Automatic
and  you can also try Reset All Networks or Reset Network Settings on your phone
What types of speeds are you getting?  There is no longer a delay in getting the new speed implemented. It's immediate.
