05-08-2022 07:26 PM - last edited on 05-08-2022 07:47 PM by computergeek541
As the $10 plan has now increased, if I switch to the $15 plan will I keep my old rewards plan ($3 discount for 3 years) or will I loose it? And secondly will I get the bonus data (250mb)
Thanks
05-08-2022 10:59 PM
Great point, fingers crossed they do the right thing
05-08-2022 08:12 PM
I wouldn't schedule the plan change yet. Don't assume the $3 rate hike is a done deal yet....wait at least a month until customers CCTS complaints have been heard. It would be a shame if you changed plans and the $3 rate hike has been rescinded.
To contact customer support :
Submit a support ticket via Simple--Simon the chat bot Click here
Or if you prefer or cannot submit a support ticket you may send a private message : Click here
To pre-verify add in your private messaging only your full name, address, email, phone # & 4 digit account pin #
05-08-2022 07:39 PM
@splichiz you may have chosen that solution in error. I know it is very easy to do, as I have done it myself, 😊.
It would be best to change your solution to one of the other posters posts as your solution so it may help another member having the same question you have one day.
05-08-2022 07:37 PM
Thanks for for info 👍
05-08-2022 07:32 PM
@splichiz no worry, you will keep all your rewards after a plan change
Just a reminder, make sure yiu understand the difference between Change plan now and Change in the next renewal date
05-08-2022 07:28 PM - edited 05-08-2022 07:30 PM
You will keep your rewards. Do not switch to the new points program or you will lose your rewards.
Edit: Yes, $15 plan includes 250 MB with autopay.
