06-24-2025 02:13 PM
I'll be getting a new phone soon. Can I take my existing SIM card to the new phone?
06-24-2025 02:18 PM
yes, if you have physical sim. And the pros for sim is that it can easily switch phones
06-24-2025 02:17 PM
hi @BRHorne
yes, you can easily move the sim from old phone to the new one. Just in case you find the sim is too big on the new phone, you should be able to pop it out from the precut frame
06-24-2025 02:17 PM
The physical SIM card can be taken out and inserted into another phone.
There are 3 sizes for SIM cards. Just adjust the the one that fits your phone.
Also, if your phonebis compatible, you can download the Public Mobile App to your new phone and purchase an eSIM.
06-24-2025 02:17 PM - edited 06-24-2025 02:18 PM
@BRHorne wrote:I'll be getting a new phone soon. Can I take my existing SIM card to the new phone?
Hey @BRHorne
Yes. It's super easy. Make sure the new phone is turned off, slide in your PM SIM card and start er up! It's that easy.
Side note, if it's a phone that takes eSIM, that's an option as well. Just download the app and purchase an eSIM for $5 and then the physical SIM slot is open for other providers or vacation SIM cards.
