02-15-2022
11:44 AM
02-16-2022
12:04 AM
computergeek541
Hi
How can I disable autopay for a while I'm travelling for 2 months?. and how long my phone number will be kept without monthly payment?
02-15-2022 05:26 PM - edited 02-15-2022 05:27 PM
Thanks.
Autopay can also be disabled via 611 if you know your 4 digit account pin #.
02-15-2022 03:15 PM - edited 02-15-2022 06:51 PM
@Meow wrote:
@darlicious wrote:Here are your options for your service when travelling outside Canada:
- You can turn off autopay
Is there direct way to turn autopay off? I could not find it and only solution I could provide is to remove credit card info.
Login to your self-serve account.
Select Payment --> Automatic Payments --> Remove Autopay
IIRC, it used to say disable autopay. I am not sure whether remove = disable or not.
Update: I just tried it. It disabled my autopay. But the cc registration is still there after remove autopay and you can enable autopay again without re-enter you cc info.
02-15-2022 01:10 PM
02-15-2022 01:02 PM
Log In Self-Serve, and remove your credit card, and re-enter when you come back,be careful not over 88 days,
and read about Reactivate a suspended plan (publicmobile.ca)
02-15-2022 12:45 PM
Most important mark on your calendar day 85 of your suspension and day 90. Do not forget when you must unsuspend your account via lost/stolen and/or pay and reactivate your service so you don't lose your phone number and account. Happy travels!
02-15-2022 12:44 PM
Remove credit card info and suspend service. Log in before 90th day of suspended service, pay for next month and resume service.
If you go beyond 90 days, your account will be deleted.
02-15-2022 12:18 PM
The “90 days of suspension” starts when your service expires 30 days after your last payment assuming you are on a 30 day plan. Not 90 days after you last paid and renewed your plan. As @ShawnC13 mentioned, don’t leave it to the last moment to renew as things certainly can go wrong.
AE_Collector
02-15-2022 11:47 AM - edited 02-15-2022 11:48 AM
@aminiaseman1966 Yes, you can, your number can be suspended for 90 days before your account is closed. I would recommend re-activating it around day 85 just in case there are any issues.
Edited: Sorry for your first part you can go into your self-serve and remove your credit card from the account there is no way it can be charged. I believe you can do it from your phone as well but I have never done that.
