Suscription not activated error
JessicaMG
I had a eror in the last step (after I chose a phone number), and there is a follow-up message " Something didn't go right while activating your subscription", is there anyway to solve this problem?
HI @JessicaMG
if it don't see a Public mobile sim card there already, then it is not installed, and you need to wait for support agent to reply.  They will send you the esim qr code in email and you need to scan the code to install
JessicaMG
it ask me for a QR or for enter manually the activation informatio. SM-DP+ ADRESS, ACTIVATON CODE  AND CONFIRMATION CODE
HI @JessicaMG
submit a ticket using private message first
and on the Setting -> Cellular screen, any PM esim there?  If you see one, click on it and make sure to turn on the option "turn on this line"
JessicaMG
 I am trying to activate an eSIM on my iPhone 14. I hope this information helps to better understand the issue.
HI @JessicaMG
did you activate esim or physical sim card?
can you check your sim card manager and see if the Public Mobile esim is there? If iPhone, it will be Settings -> Cellular screen
if you need support agent to help , please submit ticket by direct message:
