Planning to use US Roaming Talk/Text Data Bundle
Mike8500
Going to be in the Chicago area next week.
I want to ensure that I will be able to make calls, use data and send text messages while in Chicago next week. I have a Samsung Galaxy S24 and have purchase the US Roaming Talk/Text Bundle Add-on. Will I need to select a specific network when I arrive? I see talk of possibly needing to enable VoLTE on my phone, but I don't see that option when I look at my SIM options. I want to make sure that if need to use VoLTE, that my SIM is enabled to do it. I activated with Public Mobile in October 2022, so my SIM isn't necessarily automatically setup by Public Mobile for VoLTE calling.
Anyways to confirm this?  I tired to submit a ticket but it just gave me an error message.
Thanks,
Mike
Thanks,
Mike
Mike8500
Thanks for the advice.  I will follow those instructions.
-Mike
-Mike
@Mike8500
Yes, you will be able to use data and text and make calls using VoLTE with a S24
a reminder, when you are in US, make sure you try to connect to T-Mobile or AT&T or Verizon network . If it does not connect automatically, then change the Network connection to manual and select try  T-Mobile and AT&T manuall.
If you roaming purchase includes data, make sure you enable Roaming Mobile Data on your phone.  Change network mode to 4G/LTE
slusagm
S24 is on PM's VoLTE whitelist, so you are good to god.  Just make sure you use the T-Mobile or AT&T or Verizon network, use 4G or LTE and turn on roaming mobile data
