Subscrition not activated
Hc8
Subscription not activated.  What happens to get it activated
8 REPLIES 8
slusagm
@Hc8
@CSA_PM already messaged you, please check your community inbox here
Hc8
Please advise whats the solution.
CSA_PM
Customer Support Agent
Hi @ Hc8
Thank you for your patience. I will message you in private...
Hc8
The funds are already taken. I just need PM to to contact previous provider to send SMS message, but I always get an error message subscription not activated.
@Hc8 wrote:
5th step
OK. Step 5 is review and pay. Is it not accepting your credit card? Is it a regular credit card, prepaid credit card or US credit card? I found sometimes the postal code doesn't match or there is a space between or no space between.
Hc8
5th step
Chalupa_Batman
Are we to assume you are using the Public Mobile app to finish off the activation? If so, what step are you at or stuck?
@Hc8  You need to use the public mobile app to activate not website , if you have used the app and still not working get support to help you finish the activation
send  a  private message   To CS_Agent
