11-05-2023 12:24 PM
My profile will not display any Can US plans. It will only let me change my subscription to the the 20 gig plan or the $15 .00 voice txt plan. It will not allow me to change the all plans to the 90 day plans.
11-05-2023 12:35 PM
As others have suggested try clearing the cache and browsing data and then login to your account using an incognito window. Make sure in the top filtering that you have it selected to display all of the available plans.
If the website or the app continue to give you the same issue. You can message customer support and they will be able to help you switch your plan for your next renewal.
Please click this link below to message customer service:
Keep an eye on your mailbox here as that is where your reply will come in (envelope icon on desktop, click your avatar icon in the corner and then click messages if on mobile).
11-05-2023 12:29 PM
try logging in to your account on a laptop...I'm using Firefox and seems to be ok.
11-05-2023 12:29 PM
The website is finicky and has caching issues. Maybe try to clear cache, incognito mode or a different web browser. Even a different device or try the app itself.
