Subscription will not change
Valerie_Marie
Several months ago, I started the process to change my subscription. From the 40 dollar a month plan, to the 34 dollars a month. Every month, it says that the subscription will change the following month (for example, it told me it would change on Oct 5). Now that October 5 has passed, the subscription now says it will change on November 5. This has been going on for months. How can I get my new subscription to start?
1 REPLY 1
hi@Valerie_Marie
it could be just a browser cache problem.  Please try again using Incognito/private/secret mode on your browser to login My Account, or try using the PM app (logoff the app first and log back in)
if same, then please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
