Subscription update credit.
Ricci1
How can I get credit for a change  in my subscription, the day after it has renewed my old subscription
hi @Ricci1 PM is a prepaid carrier and they might not provide refund
but you can try to ask if it was just one day after renewal and you made a Change Now plan change
please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
eddieO
@Ricci1, did you select a change of subscription by selecting "Change now"? If so, you would have forfeited any reaming days you had left which is why it's usually advisable to select "Change on renewal". Public Mobile will likely not give you a refund if this is the case but it doesn't hurt to try asking for a credit or refund, just remember for next time. You will need to open a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
@Ricci1  pm is pre paid and no refunds , it’s why it’s advised to charge plan on renewal option instead of immediately. But you can try to dispute with support
send  a  private message   To CS_Agent
