Subscription Renewal
Thinesh
@ Mod
@ Moderator
I accidentally chose to upgrade to the new plan on renewal date instead of now. Is it possible to charge me now? Thanks!
edited by computergeek541: the users tagged above aren't moderators
Thinesh
This was a flash sale. So, If I cancel, I don't think I'll be able to get that plan..
Thinesh
@Thinesh  Log back into your account subscription add on page you will see your current plan and upcoming plan just hit cancel upcoming plan change like this in pic and go back and change plan now instead
Cancel plan change
HI @Thinesh
easy fix yourself.  Just login My Account again, go back to Change Subscription, pick the plan again and click Change Now
(in case you cannot , just go back to Change Subscription and you see it showing scheduled plan change, just cancel it and then you can pick and Change Now again)
Thinesh
