Subscription Not Activating
NellyN
Ive recently tried to switch to public mobile, and it says the payment went through for the subscription plan on my computer, but when I try to log into my public app on my phone to transfer my number after following all the steps, it gets stuck on step 6 saying subscription not activated and now I can't transfer or create a new number from public mobile. I have a iPhone 13 if that helps.
slusagm
@NellyN just to clarify, your issue is unrelated with the port.  Just an issue with sim provision.
PM can help. Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
hi @NellyN
try reboot your phone and re-log8n the app and see if it works
if same, ask PM support to help.
you can  submit by direct message:
Chalupa_Batman
Public Mobile’s protocol for porting issues is that you submit a ticket.
The Public Mobile chatbot is currently unable to create trackable tickets for members who are unable to log in. So for this reason, please use the following link to contact customer service.
hairbag1
@NellyN
use this link to message Customer Support for their help...
