Subscription Inquiry
HP2008
I see a promotional 4GB package for $24. This is the amount of data I am looking for and have been a member of Public Mobile for quite some time. How can I get this package without unsubscribing and re-subscribing? I am not interested in any of the packages currently available to me as they skip from 1GB to 20GB.
9 REPLIES 9
HP2008
I was able to connect with support via direct message and they were able to sign me up for the package I was hoping for. 🙂
I hope so, didn't work for me.
abtest
@HP2008- If you are on the 15$ plan, I don't think you will have any issues getting the change to the 24$ plan.
I don't know what rationale they used. I'm on the lowest,  I asked. They declined to me. I went through 2 reps. And they both declined me so I didn't bother.😢
HP2008
I am currently on the lowest plan and only want a but more data. 1 GB will not be enough so this package would be perfect.
HP2008
Thank you for the link. I could not figure out how to contact them.
abtest
@HP2008- What plan are you currently on?  If you are on a lower priced plan, you can ask customer support to put you on that plan.  they will usually do it as long as you are going to be spending more.
Sorry, but the $24/4GB plan is only for newly activating customers.
Sansan
As you know, this is for new subscribers only, but try your luck. Send a message to agents and ask . They will let you know. Some have been successful.  Others have not.
