04-11-2025 04:14 PM
I signed up for this new subscription, 5G, 20 gig, over a month ago and still not updated
04-11-2025 05:36 PM
HI @DMP85
it could be just a browser cache problem. Please try again using Incognito/private/secret mode on your browser to login My Account, or try using the PM app (logoff the app first and log back in). After you logged in , check the current Plan details to see if you are already on the new plan. Also check Change Subscription page to see if there is a scheduled plan change on next renewal.
if same, then submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit ticket by direct message:
04-11-2025 05:20 PM
I don’t see the plan on my account
04-11-2025 05:20 PM
I was invited as an existing member to the new plan
04-11-2025 04:50 PM
Did you port your old number to PM or did you pick a new number?
Currently there are no 20gb plan. The Mexico contest are for new members but there are invites for existing members.
04-11-2025 04:50 PM
hi @DMP85
what is not updated? you don't see the plan or you are asking for update with the Mexico contest?
