08-10-2022 08:33 PM - edited 08-10-2022 09:36 PM
08-10-2022 09:54 PM
Huh?
08-10-2022 09:22 PM
i understand your situation, they customer support agent will be investigations, you did contact them.
08-10-2022 09:06 PM
That is a part of what I was wondering thank you
08-10-2022 09:03 PM - edited 08-10-2022 09:15 PM
If these calls are not to one of PM's voicemail numbers then ...
Change your Self-Serve login password. Change your email password. Immediately. Also change any "secret question" backdoor password info you might have submitted.
Then, if the problem persists, change your phone number (in Self-Serve) and restart phone.
If you're concerned about fraud/theft, order a new SIM card from PM (a new, unopened, unused SIM card, straight from PM, not from any third-party vendor). Maybe you'll have to actually pay the full price of $10 $5, no discount, but it's a small price to pay to assure yourself that you're getting an uncompromised SIM card.
If you're paranoid (like me) then - after you've activated the new SIM card and confirmed it works - scrub the number markings off it. So that (most) people can't read your SIMID number if they get physical access to your phone.
Also dig through your device settings and enable the security feature which prevents anyone from viewing or changing device settings without a PIN/code. So nobody can read your SIMID number if they're using your device (you lend it to them during a phone call or whatever).
Treat your SIM card as a "trust no one" deal. If they're not paying your phone bill then there's simply no reason for them to need to know your SIMID number.
08-10-2022 08:55 PM
Are all of your services otherwise working normally? Calls? Texts? Data?
Was this reminder from 611 and did it warn you of having 10 minutes left? That would mean you're on a limited minute plan like the $15 plan. Or was this you trying to make a call and a recording told you were out of minutes? Is your account saying active? What recording do you get when you dial 611?
08-10-2022 08:54 PM
@Amyd wrote:No mostly local #s and on days and times I was definitely not on my phone. I only looked at my usage because I got a reminder that I was out of phone minutes and there was no way I could be.
@Amyd well that is weird. I've read other posts in the past about details showing unknowns like this. How is the possible, though really?
Look, if I were you, and I didn't know any of these numbers I may inquire to CSA about them. What do they say?
Have you googled some of the numbers, to see if you recognize any?
Public Mobile Representatives customer support agents (CSA) can be contacted by either two methods, found here:
08-10-2022 08:48 PM - edited 08-10-2022 08:57 PM
08-10-2022 08:48 PM
Can you take a screenshot of the calls and text but remove your personal information?
08-10-2022 08:46 PM
08-10-2022 08:40 PM
@Amyd wrote:There is calls and texts on my usage that I did not make
@Amyd - that would freak me out too, if I saw that.
Do any of the number look like the attached link:
If so, these are voicemail numbers. So this would be you calling your voicemail, or people leaving you messages.
Or, are they different numbers?
As for texts, that is more curious. Is it to the the same number or different ones?
08-10-2022 08:40 PM
Are you a sleepwalker? 😉
08-10-2022 08:35 PM - edited 08-10-2022 08:38 PM
maybe for voicemail number.
Edit: check out some of this # list of Voicemail Access Numbers (publicmobile.ca)
