Porting
LeoTheGreek
Can I get sent this number as well? i have been having issues for over 6 hours and am getting so frustrated
1 REPLY 1
@LeoTheGreek
For potting issue, there is a number to call to talk to live support,  they can provide update and re-trigger the process for you.  I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) .  Check the envelope icon on top right.  Call them and get it fixed
But if you are unable to reach a live support with the phone number I sent you, please message the the support team using this link instead:
