08-10-2022 03:22 PM
I purchased an add on of 1G and am unable to use it or apply it to my account. My data has been turned off and I don’t know why I can’t use the add on I purchased yesterday.
08-10-2022 09:48 PM
Is your account currently Active @KaitlinDeCiccio ? This shouldn't matter whether it is showing on your account or not, but the account needs to be Active for any addons to work.
So, you see it on your mobile in your account; properly just a refresh/cache issue on computer.
When you dial 611 does it include the data addon amount you purchased of 1GB /1024MB when you check your balances?
08-10-2022 08:41 PM
08-10-2022 04:36 PM
is your credit card is charged maybeyou use it all of data, if login from browser mobile some issue they have,
go to your account do you see that amount at Available Fund then ok go to rebuy it again,
not see at Available Fund and your credit card is charged then contact support team by CS_Agent to check it out,
08-10-2022 03:57 PM
On my phone I can see that I have purchased it and it hasn’t been used and when I sign in online it doesn’t show up in my purchased add ones but that I paid for it
08-10-2022 03:31 PM
@KaitlinDeCiccio hi when you look in your self serve account do you see the add on or is it possible it was not purchased properly,if you don't see it then try buying it again
08-10-2022 03:25 PM
use browser from computer, clear cache and cookies and use one page inPrivate mode,
