Still can't login
11-04-2022 08:51 AM
I am still having issues getting into my account. Error message below. I have cleared my browser data and cache. help !
My Account
11-04-2022 10:33 AM
I can't login. This cell service no longer works for me. Slow. no help. can't load web pages.
11-04-2022 09:28 AM
Correct, service is not restored. Very bad for PM image 😭
11-04-2022 09:20 AM
Same here, chatbot says account updates unavailable
11-04-2022 09:10 AM
Seems like it
11-04-2022 09:10 AM
ok thanks. I will wait it out. I wanted to check if my plan switched worked, i have time until my next renewal
11-04-2022 09:07 AM
11-04-2022 08:59 AM
@adsnstufff wrote:I am still having issues getting into my account. Error message below. I have cleared my browser data and cache. help !
@adsnstufff There isn't much you can do, it appears that it is down for some reason. What do you need to do? You can contact a customer service rep for help:
1. At https://publicmobile.ca/chatbot.
2. If you have trouble with Chatbot: Private message CS Agent at:
In either case you should receive a reply within 48 hours though they are typically much faster. Keep an eye on the envelope icon top right for replies.
