10-05-2019 10:04 AM - edited 01-05-2022 07:25 AM
Browsing is fine, but when I need to send an email out it goes into Gmail's "Outbox" folder and it continually has a status that goes from "Sending.." to "Queued." Do I need to set something up?
10-06-2019 01:46 AM
@QRWN wrote:Browsing is fine, but when I need to send an email out it goes into Gmail's "Outbox" folder and it continually has a status that goes from "Sending.." to "Queued." Do I need to set something up?
If using an app, SMTP server needs to be set. If wrong, messages can't be sent.
10-06-2019 01:09 AM
@QRWN Use a chrome browser and access your Gmail account and try to send out an email. Does it work?
10-06-2019 12:58 AM
Also check all your Settings. Apps like Gmail can be broken when Background Data/Sync is disabled and they become background processes (between uses). Gmail also relies on Google Services, Launcher3, and a bunch of other Googloid pollution - if any of these is disabled or denied permissions then Gmail (and other stuff) can be broken.
10-05-2019 10:08 AM
@QRWN , try going to the Gmail app, deleting cache, force close, reboot phone. Check that sync email setting is selected.
