Sms
TinaCe
  • My sms only partially works. Some messages do not come through. Checked all phone settings like APN. Help. The phone is an android Samsung s20 fe. Thanks.
APN settings are unrelated to SMS.
@hTideGnow We're called PM. Unless the name changed while I was at work today. LOL.
Hi @TinaCe As per @hTideGnow Did you just port over to PM recently? Have you been a customer for a while?
If you've been a customer for a while, one thing I like to do is go to the network settings and turn off automatic and pick Public Mobile as my service then I reboot. Then seems things  seem to work better. Let us know.
@TinaCe  Maybe try resetting the net work settings , also is it possible for you to test the SIM card in another phone and try ?
hi @TinaCe
if you just ported into PM, 2FA from other systems will take 7 days to come. Its a security thing
