01-25-2026 11:49 PM
I ported my number successfully.Voice and data work, but SMS (send & receive) does not.
01-25-2026 11:57 PM
@RebeccLee wrote:I cannot receive a inbound call as well. I only can give a call…
IH @RebeccLee
that is different from what you said earlier
if you cannot receive inbound calls, it is a stuck port
PM porting support team can help. I have sent you the porting support team number. Please check your Community inbox (https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage), check for the number and call.
And in case the poring team cannot help and ask you to submit ticket (or you rather submit ticket anyway), you can submit ticket by direct message:
01-25-2026 11:55 PM
01-25-2026 11:54 PM
HI @RebeccLee
try the easy way first. Update Carrier Profile, then Reboot phone and then Reset Network Settings
if same, go to Settings and remove phone number from the My Number menu. Reboot the phone and the reenter the number on Setting's My Number to force iMessage Re-registration
01-25-2026 11:52 PM
Yes i can receive a call but cannot use any sms, i use iphone
01-25-2026 11:51 PM
hi @RebeccLee
can you confirm if you can receive inbound calls?
and tell us if you have Android or iPhone
