07-03-2019 07:29 PM - edited 01-05-2022 08:13 AM
Hello
I am new to the community. I just changed my phone provider to Public Mobile
I use Skype a lot to communicate with my friends. If I use Skype to call my friends from my phone (with my home Wi Fi), I assume it is not counted under "100 minutes Canada wide talk", correct? Thank you.
Service
07-03-2019 07:39 PM
You really made some great choices:)
I'm huge fan of 15 plan
Welcome to pm
07-03-2019 07:31 PM
YES you are very correct .Welcome to PM
07-03-2019 07:31 PM
Hi @swallow615 , yes you're right. Skype does not count as your Canada wide minutes. It uses wi-fi if you're connected to it or it uses data if you're outside the wi-fi range.
