03-21-2023 06:16 PM
My sim card is broke , I have another old sim card here , am I able to swap them? If not how so I order a new one ? Thanks
My Account
03-21-2023 08:26 PM - edited 03-21-2023 08:27 PM
What symptoms for your existing SIM makes you think it is broken? Is the copper contacts damaged or the SIM is cracked?
03-21-2023 07:19 PM
It should be easy:
03-21-2023 06:27 PM - edited 03-21-2023 06:37 PM
@Trishp11 if the old sim card was used before, activated before, then NO. All Sim are one time use.
Please get a new sim card from local Telus or Koodo store or get it from Amazon:
Please note if you order the sim from PM online, it could take long to deliver, as many as 3 weeks
