01-23-2022
07:22 PM
01-24-2022
12:06 AM
Dunkman
I have submit my new SIM # but did not get a authentication code to activate my SIM what could be the reason. I have selected email option as I have lost my phone and is using another phone.
01-23-2022 07:49 PM
Worst case scenario you can contact customer support and after answering 3 out of 4 further verification questions they will perform the sim swap for you. But have you resumed your service via lost/stolen before you attempted your sim swap? If not resume your service and try again.
01-23-2022 07:27 PM
@zubr Are you using the SIM change from My Account-.> Change SIM card?
did you pick sending the 2FA code to your email or old SIM?
If you haven't try sending to email yet, try that option. And make sure you check the Junk mail folder
01-23-2022 07:27 PM
01-23-2022 07:48 PM
Yes selected email option as I don't have my original phone , check my spam nothing.
01-23-2022 07:48 PM
Yes I did nothing
01-23-2022 07:49 PM
01-23-2022 07:49 PM
01-23-2022 07:50 PM - edited 01-23-2022 07:51 PM
@zubr You can try again with My Account-Change SIM card Give it another 30 minutes.
If still nothing, open a ticket with PM Support and see if they can manually process this for you
1. For faster response (2-48 hours), Click on the bubble in the lower right to request CS Agent assistance, or use this direct link: https://publicmobile.ca/chatbot.
Start with typing "Submit a ticket", click "Contact Us", click "Other" from the choices, click "Click here to submit a ticket". Then follow to complete the ticket submission.
2. Or you can Send a private message to the CS Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
**Monitor your Community inbox, envelope on the top right, after ticket is opened. CS Agent will reply and work with you via messaging there
01-23-2022 07:50 PM
@zubr wrote:Yes I did nothing
@zubr - so, you are just trying to swap the SIM number on a lost or damaged SIM card, right?
Can you try again through your Self Serve Change Sim Card feature?
IF it does not work, ask CSA's for help. Contact them here: https://www.publicmobile.ca/en/on/get-help/articles/contact-an-agent
01-23-2022 08:27 PM
@zubr wrote:I have submit my new SIM # but did not get a authentication code to activate my SIM what could be the reason. I have selected email option as I have lost my phone and is using another phone.
Try the change SIM link again in 'my account' and if still it doesn't work, send a direct msg to support agents at CS_Agent.
