Sim card
Sue76
Can I remove my sim card and use a different one whiletraveling for  amonth and not lose my phone # or validity of myPM Sim card?
7 REPLIES 7
Sue76
Thank you so much!
HI @Sue76 if it is a month,  you might be able to save couple days or 2 weeks or so depends on the time
You can turn off "Subsxribed" on the Payment tab on My Account before you leave for the trip.  The plan will still continue till the end of that cycle but won't renew as you turned off Pre-Authorized payment via turning off Subsribed there.   When you are back from the trip, just make a manual payment to  resume the service .
Sue76
Thank you, it'll be a month.
HI @Sue76   how long you will be travelling?
if only short while, there is no point to really suspend the account as PM is prepaid, they won't refund you the days you don't use the service
If you travel long, yes, suspending account will save money, but make sure you reactiate the service within 90 days or you will loss your number
Sue76
Thanks! I wouldn't have known about suspending account!
Dunkman
Yes, you can removed PM Sim card and use another one while traveling.  Just need to re-insert your PM card when you get back.
To safe some money, you can turn off autopay and let your account go to suspend status.  If your account is suspended more than 90 days, your account will be permanently closed.
@Sue76  Yes you can
