Sim card
audreytalbot
Public mobile won't let me save the sim card
Timer
@audreytalbot
Outdoorsman
@audreytalbot hi did you have your account in lost/stolen mode? if so go back and resume service
dust2dust
Do you mean like in the change sim function? Are your services active? Or are you suspended? Can you try a different browser or even device or use incognito mode.
Adding - so does everybody have this as a "signature" now? A few ideas but always throwing in the contact support?
HI@audreytalbot   try to change sim card in My Account?
I might have seen another post about this problem yesterday.
Make sure your sim card is a new , never activated sim card
Then try to use Incognito mode to try again  (or clear cache and relaunch browser, or use a different browser)
If that still does not work, open ticket with CS agent and they can manually swap the card for you
open a ticket with PM CS Agent at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
start by typing : Contact CS Agent
then Click "Contact Us"
then Click "Other"
finally Click "Click here to submit a ticket"
