3 weeks ago
paid for a subscription and received a physical sim card. downloaded the app insert the sim card. now the app asking me to pay for new subscription. so far not a good experience.
3 weeks ago
hi @anahid
the support centre is closing soon for the night. Message them again for update
if still no answer tomorrow, message them again tomorrow morning
3 weeks ago
No one got back to me. been 4 hours, shouldn't be this hard to switch carriers. Worst experience so far.
3 weeks ago
I'm using the correct username and pass. I deleted the app and installed back. Same result. I have my whole family with PM but never had issues before.
3 weeks ago
hi @anahid
are you using the correct username and password? And you are using the Public Mobile app? Uninstall, reboot your phone and reinstall again and try
if same, ask PM support agent to help, you can submit ticket by direct message:
3 weeks ago
You won't need to pay again, ask PM to help.
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
