Sim card
02-26-2021 08:13 PM - edited 01-06-2022 02:12 AM
New Sim card accidentally added to suspended account. I bought pm phone . Will old pm sim card work if I put it into my phone if I reactivate it. It said I can make a payment. Can I remove my new sim card and enter it under new account with pm. Help please 🙏
Service
02-26-2021 10:48 PM
I guess you have an suspended account you want to unsuspend?
If that is the case, go to that acccount and check the last 4 digit of the SIM card, match with your physical SIM card. you can pay the account, click re-activate the account. Then use the SIM card you just matched up on a phone. That is the SIM going to be working once your account is re-activated.
02-26-2021 08:32 PM
If you have entered the new sim card # in your suspended account ( change sim card) then your old sim card is no longer valid. You cannot reuse either card if they have been registered in the system ( either by activation or the change sim card feature.) You will need a new sim card to activate a new line.
02-26-2021 08:21 PM - edited 02-26-2021 08:22 PM
@Kerbear7 wrote:New Sim card accidentally added to suspended account. I bought pm phone . Will old pm sim card work if I put it into my phone if I reactivate it. It said I can make a payment. Can I remove my new sim card and enter it under new account with pm. Help please 🙏
@Kerbear7 , it doesn't sound like you need a new account with Public Mobile. Unless you are want a 2nd number.
If you replaced the SIM card #1 in your self serve account with another one, #1 cannot be reused....but you ask an interesting question? At the time you changed it your account was/is in suspended status. Is this right?
02-26-2021 08:17 PM - edited 02-26-2021 08:19 PM
@Kerbear7 : Sounds like you have yourself a spare SIM. Yes, you can use the old SIM in this "new" phone. If the account on that SIM is simply suspended then you can reactivate it and carry on.
Edit: erk. glass of wine in me. nvm
02-26-2021 08:16 PM
Can you explain further? Did you go into self service in your suspended account and choose Change Sim Number and changed it to your new SIM card? If you did your old SIM card will no longer work.
