Sim card
09-21-2019 11:04 PM - edited 01-05-2022 07:13 AM
09-22-2019 08:37 AM
I found that activating a sim card always worked best with chrome. I first used Opera and and issues. Used chrome and it went though
09-22-2019 06:50 AM
Happened to me before, I just tried using another browser and it went though.
09-21-2019 11:49 PM
Yes and clear your browser and go into secret/incognito mode.
09-21-2019 11:08 PM - edited 09-21-2019 11:10 PM
@asproule wrote:I ordered a sim from public mobile and it is coming up as invalid
Try again in 1 hour. If you tried to set up but clicked back, it takes that time to reset.
09-21-2019 11:06 PM
@asprouleJust to double check the SIM card serial number is the 19 digit underneath the left hand side bar code starting with 89122?
09-21-2019 11:06 PM
You ordered the sim...recieved it and now it's invalid. Is that correct ?
