Paying with a debit card expiring 2025
bucky89
I am trying to make a payment with a debit card expiring in 2025 but the options for expiry year only go up to 2024 in the card info section for some reason.
I hope theres a solution to this, can anyone help?
bucky89
For anyone else with this problem, as I am not the only one..
I would like to point out that there was no solution from Public Mobile except using a card with an expiry before 2024. Good luck
will13am
@bucky89, if a top up is urgent, try buying a voucher from recharge.com.
Lieux
Ask for help to the moderator here..https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437 and explain your problem. Waiting time is up to 48 hours.
