Sim card
06-28-2023 07:50 AM
06-28-2023 10:03 AM
you could also activate by eSIM. Public mobile is offering them free online for a limited time.
06-28-2023 08:45 AM
@Sherbear75 wrote:It is not a new phone - I want to switch carriers - so I wanted to you my active sim card but switch to public mobile - thanks for responding
@Sherbear75 - Check out the Get Help Articles for transferring from another provider into Public Mobile:
https://www.publicmobile.ca/en/ns/get-help/articles/transfer-your-number
06-28-2023 08:12 AM - edited 06-28-2023 08:16 AM
@Sherbear75 If you’re wanting to join PM you need a new PM SIM card and activate it . But your old provider sim needs to be active to port number over to PM . Leaving old providers SIM card in the phone you will receive a confirmation text to port by replying YES to the text .you have 90 mins to reply . Then put the new PM SIM card in phone and reboot the phone
Adding you can port on activation or pick a temp phone number from PM then transfer . Either way when doing this it will ask for old providers account number and IMEI just use the account number as the IMEI is not necessary and only tends to cos hiccups
06-28-2023 08:11 AM
you can only use a new PM sim card to activate PM account/service. You can get a Public Mobile sim card from
- local Telus/Koodo/Mobile Klinik stores: https://www.publicmobile.ca/en/bc/pick-up-SIM (call ahead to confirm availability )
- Amazon.ca: https://www.amazon.ca/dp/B07R6P5KBB/ (Free Prime Shipping)
- PM online: https://www.publicmobile.ca/sim-card (Delivery could take anywhere from 5 days to 3 weeks)
06-28-2023 08:09 AM
Sorry - use my current sim card 🙂
06-28-2023 08:08 AM
06-28-2023 07:57 AM
@Sherbear75 you can use your current active sim card in another phone
but 8f you meant activate new account with current sim, then no. Only new, and unactibatved sim can be used for new account setup. You will need to get a new one from nearby Telus/Koodo stores. Call for availability before you go
06-28-2023 07:54 AM
@Sherbear75 You can if you just got a new phone take SIM card out of old phone and put in new phone that’s it . But note a SIM card can only be activated once . So if you have an old SIM card that used to work and no longer does . You can’t reuse it .you would need a new SIM card . And create a new account .. more details of what you’re trying to do would be helpful to advise further . Are you trying to activate ? Or replace a SIM card ?
