My Phone service is not ringing on my device
WpgJets204
My phone service is not ringing my device but I do have access data.  Perhaps this is because I changed my subscription plan to day?  Please advise ... Ty
@WpgJets204 - areas were reporting service issues since yesterday, and still some today.
Use https://istheservicedowncanada.com/status/telus/map then zoom into where you are to check for outages.
v_v
Change to 3G network, then change back to LTE after an hour.
dust2dust
Can you try the sim in another phone?
Hollister
@WpgJets204
Did you accidentally put your phone on do not disturb?
hairbag1
@WpgJets204
please try restarting the phone to see if that helps.
