lost sim
Moha78
I lost my sim card while travelling. I want to keep my number and plan. What do I do?
1 REPLY 1
HI @Moha78
buy a new sim card in person from Telus or Koodo or Mobile Klink store, or via Amazon
after you got the card, login My Account and update the sim card number from Profile page.
When you login and it will send you 2FA code but you can't receive via SMS.  So, click Didn't Receive code or Resend code and see if you have Send Email or Send voice message option (with send voice message, call yourself using another phone to retrieve Voicemail)
If those option not there, ask PM support agent to help.  Submit an Expert Messaging ticket (Please use the same Community login you are using now.  If you get stuck with the login or 2FA code, then use a different email address to create another Community account and submit the ticket with this new account):   https://expert-messaging.publicmobile.ca/guest/chat/
          At the Chat, type "Submit Ticket", then type "Connect Agent", and type "Connect Agent" again.  Then login to open ticket
Support agent will reply within 2 to 4 hours.  You will be notified via SMS/email or monitor here:
Remember: Support hours of operation: 9 AM to 10 PM ET
