09-19-2025
09:21 AM
09-19-2025
02:43 PM
computergeek541
Hi,
I am public mobile customer, I am going to Calgary for 7 days, I would like to know how to buy a physical sim card data + talk , so when I get to Calgary I can swap my sim card.
09-19-2025 10:03 AM
Login My Account, check Subscription & Add-on page and see what is the plan description
unless it say "Provincial" calling, then it is not Canada-wide. If you don't see the word Provincial, then your service is national wide and no need to worry about new sim card or new plan or add-on
on the side node, AB has cheaper tax, some people will go and buy Public Mobile voucher and load the voucher in the account to save some tax.
09-19-2025 09:50 AM
yes, the 3 ways to buy sim card are just the physical sim card only, you need to subscribe plan if you need new service
however, as said above, if you have a plan with PM already, the plan should be Canada wide for voice, text and data. You do not need an new account (unless you are trying to set up a new plan for family member)
09-19-2025 09:44 AM
What about data ?
If I buy this from Amazon, does it include data or I have to subscribe a plan
09-19-2025 09:43 AM
09-19-2025 09:41 AM
Hi,
What about data ?
09-19-2025 09:20 AM - edited 09-19-2025 09:21 AM
if you are already a PM customer, your service would work in Calgary without a change of sim card or the need to buy another plan. Your plan should have Canada-wide calling for calling Canada from within Canada for free. And Mobile Data is National wide as well
and just in case you need to get a new Public Mobile sim card, you can get it from
09-19-2025
09:11 AM
09-19-2025
09:19 AM
Hi,
