Sim Card Suddenly Stopped Working
euhenp
Hey All,
My sim card suddenly stopped working. I had the sim card and same phone for over 6 months.
Always on automatic payments, and always paid on time.
The phone says, Emergency Calls only.
Tried the sim card on a different phone. Same result, emergency calls only.
Tried resetting the phone, and network settings manually. Same result, emergency calls only.
Please help,
Eugene
9 REPLIES 9
@euhenp wrote:
I can login, I haven't dealt with credit card fraud.
You can login @euhenp , that's good, but you didn't mention if your account was Active or Suspended.
If Active status, check if your phone is blacklisted here: : https://www.devicecheck.ca/check-status-device-canada/
If not blacklisted, try:
  • turn off your phone, remove your sim card, gently replace the sim card, restart the phone
  • toggle into /out of airplane mode.
@euhenp
One last thing you might want to check. See if there is an Telus outage in your area. It happens once in awhile.
https://istheservicedowncanada.com/status/telus/map
euhenp
I did submit a ticket.
Yummy
If your account is active and bill paid it could be your SIM failed. Try to clean contacts and try again.
euhenp
I have been receiving text message that payment went through.
euhenp
@euhenp did you checkbif your My Account show Active?
did you try your phone and sim card in another area just incase it is a network issue?
if it is really a sim card problem, open ticket with PM.  They will troubleshoot with you to confirm.  You can try to ask them to reimburse the cost for a new sim card
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
**Monitor your Community inbox (envelope icon on the top right) after the ticket is opened.  CS Agent will reply you there
RossN
@euhenp hi call *611 or sign into your self serve to see if your account is active or suspended , it is possible your auto pay failed
dust2dust
Can you login to your account? Did you possibly deal with a credit card fraud somewhat recently?
