07-22-2021 06:27 AM - edited 01-06-2022 03:02 AM
Hi all. I'm new to the Community as I've never had a problem with PM...now I do unfortunately. My data was used up so I put another $25 on using a voucher. Although it says I have $25 worth of data, I am unable to use it.
I have a Galaxy 9. At the top it shows ? and network sign. When I scroll down it asks me to sign into Public Mobile. When I do so I get "You are unable to access the Web" due to several reasons, all of which do not apply to my situation. I really could use some help with this. Thank you
07-22-2021 10:40 AM
07-22-2021 10:05 AM
Hello
07-22-2021 08:25 AM
Are you having trouble signing into your self serve account? Did you add the voucher via 611 on your phone? With the $25 what is your intention for your data needs? You can....
When signing into your account especially to change something you should always....
Or you can purchase data via 611. Here is the menu....
07-22-2021 08:24 AM
That is an unusual message for using up your data. Does your talk and text work fine? Is your account status active or suspended? When is your next payment date? Which plan are you on? Are you able to access your PM self service account?
Are you trying to renew your plan earlier? Or are you buying a data add on? Data add on is $15 for 1 GB data add on.
You likely loaded the voucher to your available funds/balance. You will need to decide what you want to do with the funds. If you want to renew your plan earlier (ie. $25 plan), then you will need to contact moderator for help.
07-22-2021 06:34 AM - edited 07-22-2021 06:36 AM
@Pyrocynical1 wrote:Hi all. I'm new to the Community as I've never had a problem with PM...now I do unfortunately. My data was used up so I put another $25 on using a voucher. Although it says I have $25 worth of data, I am unable to use it.
Hello @Pyrocynical1
Note that purchasing an add-on is a two step process.
You should be able to use it instantly.
1-First you need to add the $ to your account and
2-then add the add-on to your account.
Don't forget to restart your phone.
*You can make the purchase via self serve account or by calling 611 on your phone.
https://productioncommunity.publicmobile.ca/t5/Plans-Add-Ons/HOWTO-Purchasing-Add-ons/m-p/198974
If rebooting doesn't reset anything for you, also try:
If you try your SIM in another phone does the same thing happen?
