03-21-2022 12:40 AM
I just want to use the automated voicemail greeting. The generic, you've reached mailbox # (your number) please leave a message at the tone..type thing.
What is the easiest quickest way to do that? I just went into my main menu options and to greetings but it isn't all too easy or logical a set up and it seems I had to record a voicemail greeting and when I tried to just out a system greeting it was still me saying my number.
There has to be an easier way to just do the automated voicemail greeting...no?
11-03-2023 11:39 PM
Thanks so much 🙂
11-03-2023 11:39 PM
Amazing! Straight to the point and saved me an extra 30 minutes trying to figure out the dumb prompts!
03-22-2022 08:24 AM
03-22-2022 12:59 AM
@JL9 wrote:I just left dead air and that seemed to automatically give me the automated greeting, or at least one that will do for now.
Thanks for the assistance from all.
I mentioned in this in the first reply. When initiating/calling into the voicemail account for the first time, the system forces the customer to record a greeting. It's good to know that trick of an empty greeting works regardelss of when you do that.
03-21-2022 06:37 PM
03-21-2022 09:27 AM
03-21-2022 12:52 AM
I did that but when I tried to listen to that playback it wasn't the typical generic automated message I'm used to. Going to call from another # to test it and if it worked great. If not, I'll go back in to tweak it to see if I have any further luck.
03-21-2022 12:49 AM
Once in your voicemail options...(3) then (1) then (6) automated greeting.
03-21-2022 12:46 AM
@JL9 wrote:I just want to use the automated voicemail greeting. The generic, you've reached mailbox # (your number) please leave a message at the tone..type thing.
manage personal greetings, delete personal greeting
During the initital setup, I discovered if you recoded blank air as your greeting, the generic system greeting would be used instead as the system would consider the blank/empty greeting to be invalid. I suspect that having no greeting saved after deleting yours will accomplish the same.
