3 weeks ago - last edited 3 weeks ago
Does any one here use a link to cell phone set without a land line number attached to it?
Panasonic?
V-tech?
AT&T?
Does it work well? Any thing to point out good or bad?
Thanks.
3 weeks ago
@Chalupa_Batman wrote:Hey @SeniorCitizen
I think what you're referring to is a cordless phone with bluetooth capabilities?
If so, I've used Vtech myself.
My buddy has these and likes them...
Edit, I used to have a box like from Rogers back in the day. You can just slip your PM SIM card in there and set up a cordless phones. Not this one of course, this is just a sample.
That ZTE is not supported by PM. Not sure if that means they can make it be obsolete? But only good up to 4G.
I like the idea of the link to cell for the longevity. I like to use a SIM for lower cost plan of Canada wide, unlimited for $99 a year and the ability to call forward at no extra cost. Just looking for the best battery longevity, sound, and Bluetooth link to cell brand.
3 weeks ago
Yes it does work , but you must make sure they are compatible.
3 weeks ago
Costco still have Panasonic phones, but not Link to Cell. But Link to Cell, check Staples, probably pricier, or Amazon
3 weeks ago
@slusagm wrote:i had good experience with Panasonic. I was just helping a friend to setup, easy, not bad
Thanks……have a non Bluetooth at home. Hard to find a Panasonic land line now a days for some reason. I kind of have favouritism for them.
3 weeks ago
Yes thank you. Home phone with Bluetooth for 2 cells, and no landline connection. Wow Motorola….I ran a Motorola main frame years ago….big, well built and bullet proof.
Hey @SeniorCitizen
3 weeks ago
