09-11-2023 10:33 AM
I completed all steps of activation and my credit card was charged twice the same amount and I don't have services. It prompted "Services on hold". My attempts to contact someone to help ended with Error prompted
09-11-2023 11:27 AM
09-11-2023 11:19 AM
If you can call in and out and real sms text in and out and browse web pages on cell data (not wifi) then it seems you're good to go. Don't worry about how the account looks. You could use incognito with the browser and see if it shows any different.
09-11-2023 11:16 AM
Physical sim works ok
09-11-2023 10:58 AM
HI @Zbig
you submitted ticket yet?
and try to put the sim in the phone, does it connect ? Try to click Reset All networks and check if it connects again
09-11-2023 10:56 AM
with physical
09-11-2023 10:43 AM
@Zbigplease submit ticket with support using this direct link to vet straightened out
send a private message To CS_Agents click
VVVVV Link below VVVVV
09-11-2023 10:37 AM
HI @Zbig
are you trying to activate with physical or esim?
if physical sim, did you try to put the sim in a phone and test it?
we will try to help as you give us more information, but please also submit a ticket with CS agent:
