Services not working
09-04-2021 10:17 AM - edited 01-06-2022 03:18 AM
I just came back from abroad and change my SIM card back, but nothing is working. No phone, no data, no texts,…
what can I do. I can see that my plan is still payed until end of November
Service
09-04-2021 12:37 PM
It says Public Mobile with a few bars, but no connection is possible.
i have done all the resets, and still not working.
this is the same phone I used for the last 2 years and I have Public Mobile since 2016. I have been switching SIM card every time I travel from the UK to Canada and never had this problem before.
i will try one more reset and then will have a ticket with PM directly if not working
09-04-2021 12:24 PM
what is it showing on the screen?? does it show Public Mobile and some bars for the status??
This is an iPhone you uses when you traveled and inserted the local SIM before?
try plug the phone to a computer and start iTunes to see if it comes down with any update or newer Carrier profile.
A quick way is to confirm with another phone but you said you don't have one. If you are close to an Apple store, maybe you can go there to seek help. They can put the SIM on another phone and confirm
You can also try a Factory Reset..its painful to re setup the phone after but it should work
09-04-2021 12:22 PM
do one thing Make sure your phone is off before removing your SIM card,
and take your SIM card out and waiting for a 2 minute and put it back and turn on -This one is quick and simple.
what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
or can you do try reseat the SIM card
1. power off your device
2. take out the SIM card,
3. wipe it clean SIM card,
4. put it back and power on,
5. toggling airplane mode off/on,
and do again Rebooting your phone means to turn off your phone and turn it back on again.
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit Here link,
click Here link,
- Open the Settings app on your Android.
- Scroll to and tap either "General management" or "System," depending on what device you have.
- Tap either "Reset" or "Reset options."
- Tap the words "Reset network settings."
or visit Here link,
and go Changing APN Settings On Android device
click Here link,
and if still not fix it please you Have To Submit a Ticket To Customer Support Agent by CS_Agent,
Explain your issue to Contact Customer Support Agent by CS_Agent ,
they can solve your issue, they are nice service Team the will help you 100%.
Here’s how to contact Customer Support Agent by CS_Agent,
- Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to Customer Service by CS_Agent. Click Here link to get started.
- or you can send a private message to Customer Service by CS_Agent, by Click Here link.
- You’ll need to be logged in to your Community account for the link to work.
- please include in your message,
- your account number,
- your phone number,
- your account 4 digit pin,
- your Email address,
- Customer Support Agent by CS_Agent, will Response to your inbox by private message
Good Luck
09-04-2021 12:13 PM
I did all the steps I was told, but nothing is changing.
On my network is says not available and on network provider Public mobile 46.0
My SIM card number on the self serve is the same than my actual sim card
09-04-2021 10:55 AM
Thank you!! I will do what you mentioned.. even charging my phone 😉
09-04-2021 10:54 AM
APN settings are important for data, not for other services like talk and data. Apple usually will update APN settings automatically. No need to manual adjustments of APN(except older iPhones ie. iPhone 4 and earlier).
09-04-2021 10:53 AM
09-04-2021 10:48 AM - edited 09-04-2021 10:49 AM
@Salimaarnold wrote:On my Mobile Data network settings I have only the hotspot and not all the other setups:
Remove and reinsert your SIM again, then reboot.
Also check this...When you are logged into your Self Serve, go to the Change Sim Card option and ensure the 4 digits listed there match the last 4 digits of your actual SIM card.
OH, and fyi, your phone battery is low - 'charge me' it is saying.
09-04-2021 10:43 AM
09-04-2021 10:42 AM
As mentioned above, try network reset of phone. Rebooting phone. Also, can try toggle airplane mode on, then off.
09-04-2021 10:36 AM
No, i haven’t tried another phone, as I don’t have anybody to ask around me.
my phone is an iPhone.
i did select public mobile, but no changes
09-04-2021 10:28 AM
you tried your SIM on another phone?
Any chance your phone is an LG phone?
Try a network reset. Also, check the network selection, you can try a Manual selection and pick Public Mobile.
09-04-2021 10:27 AM
it says active
09-04-2021 10:26 AM
Yes, I’m on a 90 days paid in August 25
09-04-2021 10:25 AM
09-04-2021 10:25 AM
@Salimaarnold paid till end of November? Are you in the 90 days plan?
Logon to My Account and confirm the account status first
09-04-2021 10:20 AM - edited 09-04-2021 10:22 AM
