Service in Caribbean
DINEY
I want to be able to use my calling and texting and data while in Caribbean.  How can I do this?
2 REPLIES 2
Chalupa_Batman
Hello @DINEY
Public Mobile only work in Canada and the United States. There is no way to use this plan in the Cari. The only suggestion I can make is to download "TextNow" which is a VOIP app and pick a local number to where you live. You can purchase Data Only SIM cards down there.  https://www.airalo.com/
hairbag1
@DINEY
unfortunate not !  PM only has service in Canada or US with add-on or Cdn/US plan...nothing for Carib use. Maybe try Whatsapp using your local wifi.
sp
