Service disruption
Harmandeep_kaur
Incoming calls or messages are not working. Outgoing calls are working. Outgoing meessages also not Working
@CS_Agent
xw007
Both incoming and outgoing calls are not working.
Dunkman
@Harmandeep_kaur
More details would be helpful
New customer?  did you port over your number?
Did incoming calls or texts work before? Data working?
What have you tried?  Reboot your phone?  Network reset of phone?
hi @Harmandeep_kaur
we are just customers here, if you need PM agent to help, you need to submit a ticket
submit a ticket with CS Agent using Chatbot here:
             Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can submit  ticket by direct message:
And to confirm, data and text both working?  What phone do you have?  Did you try a Reset Network Settings on your phone?
slusagm
you have unlimited outgoing calls, right? (ie, not $15 or $13 plan?)
Try Reboot phone and Reset Network settings
