08-09-2024
05:25 PM
08-09-2024
05:28 PM
computergeek541
I created an account for the first time, selected a plan, paid for it, but process fails at step 6 without explaining why. It says it wasn’t activated but my visa was charged. I went through the resume activation process but I get nowhere. How can this be resolved ?
08-09-2024 05:38 PM
Yes, I was using the app and provided number I wanted ported for other cell service provider. I have contacted PM support and awaiting response. Thx.
08-09-2024 05:28 PM
hi @LCG
were you using the app and do you get to the phone number step?
either way best to ask PM support to help , you can submit by direct message:
08-09-2024 05:26 PM
@LCG You will need to contact support to help fix for you
