Service not active outside wifi
Betgargirly
The last week or so we have zero service outside wifi. We have data. And bars. But no service.
2 REPLIES 2
Dunkman
@Betgargirly
Which phone do you have?  Is it VoLTE compatible with PM network?  Check on the following link:
https://www.publicmobile.ca/en/get-help/articles/volte
If it is not VoLTE compatible, then you will have voice calling issues.  But, texting should work.
Might also want to try a reboot of phone.  Network reset of phone.
@Betgargirly
PM had a data issue last week, and you could have impacted.  But the issue was resolved now.  Please perform a "Reset network settings" after a device reboot
if issue persists, you will need to ask PM CS agent to reprovision the account/sim.   Please open ticket with PM support:
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
    Start by typing "Ticket", click "Contact Us"  then choose a topic, click "Login", finally click "Click here to submit a ticket ↗
    (if unable to receive 2FA via SMS when login, click "Didn't Receive code" or "Resend Code"
                then choose "
Send email" or "Send Voice Message" to get 2FA via email or voicemail)
