Cellular Data is not working
TonyJ67
Hi,
For the past couple of weeks, my cellular data has not been working when I am outside, even though I have used very little data.
Could you please look into this?
2 REPLIES 2
CSA_PM
Customer Support Agent
@ TonyJ67
I sent you a private message. You can view and reply to it by accessing this link: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
hi @TonyJ67
what phone do you have?
Make sure Mobile data is turned on, no data limit set
And if you just joined PM not long ago, make sure old esim is disabled, or old sim card removed
Try Reboot phone and click Reset network settings
if same, then submit a ticket with CS Agent using Chatbot here:
             Type the question "Ticket", Then click the following in order: "Account Management" , "Log In".
             (If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit  ticket by direct message:
