Service Not Working
Zoey101
I purchase a SIM card and activated a plan. On my account it says “Active” but my service does not work. I can’t receive calls, send texts or make calls. I have an iPhone so all it says is SOS. I’ve paid for the plan and added an extra $40 to my account figuring I needed to do so to activate the plan. Why is my service not working? Please help!
9 REPLIES 9
pmva
@Zoey101 If your phone is showing SOS then it's not connecting to the PM network.
- Are you within range of a Telus tower..are you somewhere urban or somewhat rural where coverage could be spotty?
- did you port an existing number to PM or is this a new number?
- Is this this an unlocked phone you have?
- have you tried restarting the phone with the PM SIM installed?
@Zoey101
well if it recently worked for a Kodoo plan...it'll work on a PM plan.
Follow suggestion of @HALIMACS  and try that sim in a different unlocked phone. See if it'll work.
@Zoey101 it should be unlocked,
You can find out if your iPhone is locked by going to Settings > General > About. If "No SIM restrictions" appears next to Carrier Lock, your iPhone is unlocked.
but again, did you check if the phone is clean as advised above?  again, this is the site
https://www.devicecheck.ca/check-status-device-canada/
And you have another phone to test the PM sim?
Zoey101
It recently worked under the Koodo network from January-March. Recently tried switching to PM as they offer a better plan for cheaper.
Zoey101
The phone was purchased this last Christmas used as a gift. It is an iPhone 11. I was under assumption any phones after 2017 are automatically unlocked?
Yummy
Did your phone Ever worked as a 'phone'?
Maybe it is blacklisted? Broken? Broken connectors to SIM? Locked to previous provider?
Did you try any other SIM to isolate issue (phone or SIM)?
HALIMACS
@Zoey101
To be certain the SIM is ready to provide service, try it in another device which is known to be working (if available).
This will point to whether a Public Mobile (SIM/account) issue or a device issue.
hairbag1
@Zoey101
is the iPhone locked to previous network ?
If so, you'll need to contact them to unlock said iPhone befo9re it'll work with PM.
added
click Settings / General..scroll down to find Carrier Lock which should show No SIM restrictions.
If you use devicecheck.ca, is the status of the IMEI clear?
