09-01-2020 07:34 PM - edited 01-05-2022 01:02 PM
Every time I log in to my account, there is virtually no information shown, the fields are blank. If I try to click on Plan and Add-Ons, it says Oh no! Something went wrong... try login again...
But each time I try again (and I've tried on different browsers even) it continually says same message. 2 of my family members also have accounts and their accounts work perfectly fine, showing all the information they should. Also the Overview page has no information shown, pretty much a blank page.
09-01-2020 08:13 PM
@dlianne I had this same issue a while back which was caused by my ad blocker. Once I turned it off for the Public Mobile sites I no longer had the issue.
That being said I have no idea why it would work for others on the same computer and browsers. As mentioned by others before it would probably be best to reach out to the moderators if you haven't already.
09-01-2020 08:02 PM
Yes, exactly! Thank you, I'm trying the moderators now so hopefully they can help! 🙂
09-01-2020 08:00 PM
@dlianne wrote:Thank you , just tried this and no change... like I said, it's weird because other accounts accessed from the same computer and same browsers are totally find, it's just mine that has a problem.
Hi @dlianne ,
Well, that is a bit strange if the same computer is being used, yet different accounts are working and yours is not.
Hopefully, the moderators find something that can be corrected!
09-01-2020 07:57 PM
09-01-2020 07:51 PM
@dlianne if this happens everytime, contact the moderators and ask them to look into it for you. There are 2 ways to contact the Moderator Team:
Once connected to Simon, you will be asked to log in again with your community user name and password. Please do, this allows you to continue and send your message.
- Keep an eye on the envelope top right of your screen. The mods answer will show up there. When it does, you will be asked to verify your self service account, with your password and login. Doing so allows the process to continue. Stay safe.
09-01-2020 07:37 PM - edited 09-01-2020 07:38 PM
@dlianne ,
No worries, this can happen.
Try clearing you cache, opening up a tab in incognito mode.
You can also try restarting the device you are using. Does the device you are using need any upgrades?
