10-28-2016 02:01 AM - edited 01-04-2022 03:46 PM
I have 2 questions:
Thanks in Advance,
MS
10-29-2016 04:57 PM
Your XT1540 will definitely work on both HSPA and LTE here at Public.
10-29-2016 10:16 AM
Just to clarify
3G WCDMA is the BARE MINIMUM requirement for Talk, Txt and Data
LTE is essentially optional, as currently PM has NO VOLTE, ONLY the Data LTE
10-29-2016 03:38 AM
Thanks, everyone.
The device is an international version SM A500h, I checked the link, it turned out it's not gonna work with 4G LTE Network. However, I have another unlocked phone Moto G 3rd gen 540, bought from Canada which should work I guess.
Thanks again.
10-28-2016 09:03 AM - edited 10-28-2016 09:04 AM
Did you originally buy the phone locked to a provider? Is it an international or American phone or did you buy it from a Canadian provider.
If it was in Canada it is most likley to work with Public Mobile without issue.
If it was American you will probably be fine with Att and Tmobile phones. It could be hit or miss with Verizon or Sprint.
10-28-2016 08:11 AM
Hi @meftasadat;
With the A5 it depends on the sub model, the site @NDesai is quite reliable in determining if yours will work. If you do go with a 10 day plan to test, I would go with a data plan in your case, slightly more expensive but a better indicator of how well your phone will work.
10-28-2016 02:54 AM
1. It depends on your model number. Check if it will work or not here: http://willmyphonework.net/
2. No, you cannot test without activating the sim. However, you can activate with the cheapest 10 days text only plan for $11 to test.
